Hi there,
I'm really hoping someone can help me on this one.
I've just moved house and the boiler's started playing up (typical, when it's so chilly out).
I got home from work yesterday and the house was freezing. On checking the boiler it would fire for about a minute then cut out.
It was running for hot water though, and if I ran the hot bath tap and then turned on the CH it would run for a couple of minutes and then cut out.
Eventually, I got round to checking the pressure guage underneath the unit and it was borderline in the red (about 3 bar).
I checked the forums and read a couple of articles where people had opened the valve at the bottom of the house to run of some of the CH water and hence reduce the pressure.
So I did this, but ballsed it up and let out loads of water. When I checked the guage it was pretty much at 0 bar, so I left it alone and called the plumber who said he could come round first thing this morning.
Anyway, when I woke up, the pressure was reading just above 1 bar (10 hours or so after I'd flushed it).
Low and behold, the boiler fired and the house heated up, although the pressure did seem to rise quite quickly. I called the plumber, and he pretty much said there was no point in him coming over, but to call him if things went up the swanny again.
I turned off the boiler and went to work, but when I got back home, the pressure was back up above 3 bar. I bled off the water as before (bringing the pressure down to 1.5 bar). Hey presto, boiler worked, but within an hour the pressure was up to 2.5.
I realise that I'm gonna need to get the plumber in on this one after all. If anyone can advise in the short term whether bleeding it off is ok so I can keep me and the Mrs. warm, I'd be really greatful.
Cheers,
Rob.
Cheers,
Rob.
