Several hours after switching on my hot water (I only heat the water when I need it) the boiler switched itself off, this turned out to be the fuse in the boilers 13A plug. I've replaced the fuse & relit the pilot but when I try to switch on either the CH or heat the water the pipes near the boiler start to bang and the system doesn't start up.
It is a Myson Apollo Fanfare conventional heating system and in this picture http://www.byphotos.com/album/album_photo.html?c_photo=4673772 the top two pipes seem to be the ones doing the banging, around what I think is the circulator pump.(not too clued up on heating systems)
Any ideas what could have happened to cause the fuse to blow & what has possibly went wrong with the system?
