Strange Goings On with Boiler: Pressure Surging when Hot Water Goes On
I bled my radiators a few days ago as the top of the radiators weren’t getting warm. I probably collected about 1-2 litres of water in the process.
That afternoon I noticed that the pressure on my boiler had dropped below the acceptable green range.
So I let some water into the system until the pressure gauge moved up to the desired level (1).
I noticed a few hours later that the pressure had dropped a little, so I put in a bit more water to take the pressure gauge back up to 1.
Then I put the hot water on and the pressure gauge rose to way beyond 3 *PANIC* (no water was flowing out the pressure relief value was newly fitted about 6 months ago?)
So I drained about 5-6 litres out of the radiators to get the pressure gauge down to 1.
Next time I put the hot water on it rose to about 2.5-3. (hot water not on for as long previously as I was keeping an eye on it)
So I emptied another 3-4 litres out of the system by bleeding a radiator.
Yep you've guessed correctly, next time I put the hot water on it rose rapidly again.
I bleed another 3.4 litres from the system.
I don't want to bleed the radiators dry, so what do I do next? Ay idea as to what has happened?
All was fine before I tinkered with the radiators
Any help and advice will be very much appreciated indeed
Note the pressure doesn’t rise as much when I put the central heating on if that’s any help
