I have 2 boilers in my house x1 for the radiators and x1 for the water (when you turn the hot tap on the boiler runs) i just wondered if you can buy a single boiler which will do the both?
Had a quote to remove the 2 boilers and replace with the 1, £2200 for the job, he said that the system (by law) has to be chemically cleaned flushed, is this true? and the heating system has to be a closed system (the small tank has to be removed in the loft?
