Hi - thanks for reading
I am about to replace my Baxi System boiler with a Worcester 30cdi system boiler retaining the current Megaflow water tank in the sealed system.
There is currently no CH system thermostat although all rads have thermostatic valves. The system is currently controlled using a wired programmer near the Megaflow which allows me to select CH or just Water if i need to boost the tank. I am not sure but think that the controller is currently activating a (three way ?) value near the Megaflow which is closing the CH circuit when Water only is selected
Q1 - do I need to change the current controller or just have it wired into the Worcester ?
Q2 - what would be the benefits of fitting the Worcester divertor kit ?
Many Thanks
B
Many Thanks
B
