Boiler shutting down when energising S/L?
4 Sep 2022
Hi - I’ve upgraded old stat for new Nest stat and heat link - all working as it should, except that when switched live is energised via 3-port valve (orange) or cylinder stat, it seems to switch the boiler off?
Boiler is Ideal Icos HE15
3-port Danfoss HSA3
Cylinder stat Drayton HTS3
All wired up as per Nest wiring diagram
Have checked S/L to boiler, getting 240v when called for, so functioning as expected.
However, I’m getting 240v FROM the boiler on S/L connector (having disconnected from 3-port) - is this correct?
As above, when all connected, boiler sits on standby - when 240v is sent to S/L, it’s as if boiler powers down.
Separate pump is connected to same terminals and operates as expected.
Any thoughts would be appreciated!
Post pics of your wiring, the cyl stat should not be connected the the S/L of the boiler it send power to the mid position valve and the orange wire from the valve tells the boiler to fire, not the cyl stat
