Boiler Size Opinion
Discussion in 'Plumbing and Central Heating' started by Kerjakp, 27 Nov 2021.
  1. Kerjakp
    Kerjakp
    27 Nov 2021
    2
    Thanks Received:
    Country:
    Appreciate if I could get a couple of opinions on below.
    Daughter has 2 bed flat 11 rads total(7 actual rads but some double panel)
    Had a 28cdi (24kw 10l flow rate) fitted on understanding this would heat flat and be OK to run a shower off of as well when electric shower is eventually replaced.
    Seems a bit on small side for this but I'm no expert and would be grateful for any advice or opinions.
    Many thanks.
    John.
  2. Madrab
    Madrab
    4 Oct 2012
    8,561
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    It kind of depends how large the rads are but if they all average out @ say around 600x1000 K2's (Type 22) then there's loads of headroom in that boiler to cope with that demand.
    It will cope with a normal mains fed bar shower too @ 10L/min, that's also dependent on the cold mains pressure and flow or course.
  3. Sponsored Links
  4. oldbuffer
    oldbuffer
    6 May 2010
    1,493
    Thanks Received:
    560
    London
    Country:
    1. Average radiator is 1.5 kW, obviously some more, some less. 7 x 1.5 = 10.5 kW heating load.
    2. Shower should be OK for anything but a giant rainhead.
    28 cdi should be fine.
  5. FiremanT
    FiremanT
    16 Jan 2012
    9,522
    Thanks Received:
    1,912
    Uk
    Country:
    Which element are you concerned about? Heat or HW, or when both are on?
    If, as I suspect, it is the latter, then worry not. If the heating is ON , and you demand HW, the effort is diverted entirely to HW, and the CH is OFF.
    It is plenty big enough.
  6. Sponsored Links
  7. Kerjakp
    Kerjakp
    27 Nov 2021
    2
    Thanks Received:
    Country:
    Many thanks for replies.
    Majority vote for boiler ok and mind now at rest.
    Cheers,
    John.
Loading...
Share This Page
