- Joined
- 27 Jan 2008
- Messages
- 29,286
- Reaction score
- 3,598
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Working is not the same as working efficiently.I have a 5 bed mid terraced house, rooms are not that big, during buiolding works in 2019 i installed new combi 30kw boiler without sizing n calcs, replaced some older rads and it worked out ok.
I know I don't need all rooms to be heated at the same time, many homes have two zones, mine has programmable TRV heads as well, so I can select when rooms are heated, the largest room has two double panel radiators, so can likely sink around 3 kW of heat, even with all mid-floor rooms being heated, only around 6 kW is required, so why did whoever designed the system think I needed a 20 kW boiler?
