I have a Yeoman boiler stove connected to a buffer tank in a closed circuit. The stove only heats the water in the buffer tank.
My boiler outlet passes through a coil within the buffer tank.
I was wondering if this is correctly set up?
Or should the return to my boiler pass through the buffer tank, reheating the returning water thus reducing the temperature difference between outlet and return causing the boiler to fire less frequently when CH & DHW is demanded.
