Thats not what i said............if the pilot is passing it will give the boiler a pilot ths 'confusing' the pcb. I changed a gas valve only 3 days ago for this fault.
Had one pilot, (Profile) doing that a month ago but it just sat there, no cycling!
The flue corrosion is a common fault. A retrofit kit is available from potterton, which fits easily from the outside so no need to take the boiler off the wall(phew!).
Does any heat get out of the boiler? I know it isn't on long but on CH only it would probably warm a rad or two. It isn't easy to get evidence of water flow,( though sticking a blowlamp against a pipe, with experience...!)
Thanks Ollski. To previous threads, I have tried boiler again and there is definately water flow through pump. Rather than finding heat in a rad I have found that the pipes coming from the diverter valve have cooled (they were previously warm from conduction via emersion heater).
Thank you all for your input - it was the flue causing the problem. Explanation is - the gases being expelled from the flue were not making it outside of the house and were therefore being sucked back in thus starving the main burner of oxygen.
