- Joined
- 25 Sep 2014
- Messages
- 3
- Reaction score
- 0
- Country
Hi
Had my floorboards replaced in kitchen last week and then next day had no hot water and pressure was at zero on combi boiler so my immediate thought is they have nicked a pipe.Refilled boiler back to 1.5. (Don't know if it's makes a difference but one of the radiators has been removed off the system sinceApril as we are in the middle of works so was capped off.)
Floorboard Company came back and checked for any leaks but was a very quick visual check underneathand said everything was fine and it's a boiler issue so get a heating engineer to have a look. For next 3 mornings pressure was at zero and so have been refilling the system. Sometimes I ve had to do this twice in the day.
After the third morning (yesterday) my own plumber came to put the radiator back on, so drained the sytem bled all radiators etc. Today the pressure hadn t dropped as much say from 1.2 to 1 but I did noticed there was air in the top bathroom radiator(even after plumber bled them all the day before) which I then bled and refilled system.
Ideal came out later today and checked boiler and everything is fine, heat exchanger, pressure vessel etc. The pressure on the boiler has been stable all day.
Any ideas what may have occurred? Has a constant dripping leak turned into a very slow drip perhaps. Having the floorboard company out again tomorrow to do a more thorough check, but if there's no sign of a leak they will charge me for putting the boards down again! If there is a leak will be at their cost but as the system seems stable now doubting whether to get them to lift the boards.
Anything seem obvious what could have caused the issue, air in system, radiator capped off for a few months? Just a massive coincidence problems started after boards were replaced.
Thank you
Thank you
