boiler wont fire
15 Oct 2007
Humberside
hi my flexicom 24 boiler wont fire
it started leaking loads of water coming from the top off the boiler through the fan.
i worked out that it was the condensate pipe that had frozen and the water had backed right up and started leaking from the top of the boiler.
ive defrosted it and now the leak has stopped but now it wont fire up its sparking but wont ignite, could water have got in the combustion camber or the heat exchanger so now wont fire because theres water in them?
if there is water in them will the boiler fire up once the water has evaporated?
any advice will be appricated its freezing need the heating on
Its difficult to guess what may have happenned but the condensate cannot fill the combustion chamber as that would extinguish combustion!
Is the boiler in a place where it could have frozen up?
Is the system pressure normal?
A boiler engineer may be needed if it does not dry out and start.
Tony
yes the boiler is pressured.
the condensate pipe was ran into a downpipe which had blocked so i think the water backed up through the condensate pipe.
and the reason i asked if water could get into the combustion chamber is because it was leaking from the top of the boiler and running down over everything
