Boiler wont ignite pressure on 1.5 (moved from Information).
black water came out of the radiator pipes,about 5 litres.
If you have black water in your central heating system, it really needs a good flush out! I would do a cold flush, then a hot flush and if that does not clear the water then add a chemical cleaner. Once the water is clear an inhibitor needs to be added to the system water. If not the system and boiler is going to suffer from corrosion, blockages and poor quality of heating.
I think she may have a Biasi !
Not that its very relevant.
Tony
Null dealt with yes it's a bias!.the pulldown cover as broken were name was so wasn't sure!...thank you prenticboyofDerry for a you patience.
