Boiler wont top up - got a flexi hose with tap on it that I usually just turn to refill it when pressure low but it's stopped working
Tap is bottom left of 1st pic. There's a slot for screwdriver next to it (2nd pic) which I thought might be a valve off switch (inline valve??) but turning it doesn't help. There's another tap connected to the same pipe on the other side of the hose but turning that doesn't work, although it only turns about 45 degrees, the other taps I haven't turned - don't know what they do! Any plumbers here with helpful suggestions?
Fixed - there was a valve under right hand side of hose that was shut off
