Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
A friend of mine has a split load CU with the boiler circuit on the non
RCD side. when the boiler itself is turned on it trips the RCD? Is there a problem with the boiler? Should it still trip the RCD?
If the boiler supply is on it's own circuit then it is quite possible the Neutral is in the RCD protected Neutral thus causing an imbalance in the RCD coil.
well no, its just that there is an imbalence through the rcd
in that there is more current coming back through the neutral than going out on the live, if you understand
