BOILER
11 Nov 2007
West Midlands
I think i may have problems with my boiler. It has started to become noisy. When the hot water is turned on, the heating gets hot gets hot aswell as the water and when the heating is turned on the hot water gets hot aswell as the heating getting hot. Should this be happening? I thought if you turned the water on, ONLY the water gets hot. STRANGE!!!! Can anyone help
Sorry to keep on. But could this cause problems with heating the house? Will i still get fully function from both hot water and heating?
you will probably get full function from both but you will have no temperature control over either except the boiler stat.
sorry i am a bit thick to this. Does the valve motor? What does that mean? Sorry for my thickness. I'm very new to all this and i do want to try and understand. Thanks for your feedback so far
the valve will spring back when no demand is called for heating if its working ok
the lever on the end will be hard to move, when you select heating it will become easy to move as the valve will motor open and so the lever will be loose.
