Bolts for joists?
Hpd
23 Feb 2011
Cardiff
I’m building a flat roof which spans 4x4.5m
I have been told to use two 8x3 joists to trim out for a roof lantern going in the middle.
What size bolts should be used to bolt these timbers together? Also what spacing?
Thanks!
you can use m12 - 250mm threaded rod packsfrom amazon.
use m12 timber connectors - square plate washers an nuts to suit.
drill at 30mm from top or bottom edges an space holes on 600mm centres
  • Thanks
Reactions: Hpd
