Bonding issues - yes or no
23 Mar 2016
Hi, recently did an eicr on flats, the electrician that wired them is no longer available!?! I made a note of the lack of bonding to the mains water incomer, the builder disagrees and stated that he has had 2 electricians and a lecturer look at this and it doesn't need any due to the amount of copper present, the copper pipes drop about 12 inches below the Worktop before changing to plastic, the tank is also copper. I can't find anywhere that states the amount of actual copper piping required before bonding is necessary.
If it is an extraneous-c-p
The amount of copper is irrelevant.
Supplementary bonding is not required anywhere other than bathrooms and the like. This may be easier to do in an airing cupboard but it is not required there in its own right.
I am classing it as extraneous and they are not, that's the problem, as you can see the meter and incomer is in the picture, the problem is the builder doesn't want to get another cable from the db in the cellar below as it's all decorated and finished
What, in your eyes, makes it an extraneous conductive part?
And why do they disagree?
Because it's conductive and not part of the electrical installation,
They said there's not enough copper present
It's not a question of classing it one way or the other.
It either is an extraneous-conductive-part or it isn't. You can't tell by looking at it.
The pipework in the cupboard is probably immaterial unless it has travelled through the ground between the entry to the premises and the cupboard. If it isn't a ground floor flat then it can't have.
It is at the point of entry to the premises which counts and should be tested by measuring the resistance between it and the MET after disconnecting it from the rest of the pipework in the premises.
If this is plastic then it won't/can't be an extraneous-c-p and you will have a job getting an electrical connection to it.
So the main incoming supply is not in the picture, then.
Sorry, but should you be doing EICs?
That's not the criterion.
Because it's an extraneous-conductive-part and not part of the electrical installation.
Spoons are conductive and not part of the electrical installation
Yes the main incoming supply is in the picture, if you study the picture you will see it, this cupboard is in the kitchen with pipes dropping below,
Why would I bond a spoon? This is about a spoon is it? I'm asking for advice not abuse and not clever dick answers, I am happy to be wrong, what I want to do is ensure it's right
The point is none of us can say whether it is or isn't an extraneous conductive part - you must prove this one way or the other.
I presume you know what the definition of an extraneous conductive part is?
Yes, the pipes that feed the bathroom, what I am trying to say is that the rest of the flat is plastic piping, the only metal is in that cupboard and drops below changes to plastic and off it goes to the bathroom
You wouldn't, because it is not an extraneous-conductive part - any more than is pipework unless, as EFLI has said, it has travelled through the ground subsequent to entering the premises (and being bonded there).
It wasn't a 'clever dick' answer - it was a useful analogy, to try to help you to understand. You have been given the right advice. The pipework only (possibly) needs main bonding if it is an extraneous-conductive-part, and nothing you have told us so far suggests that it is.
Kind Regards, John
