Ive noticed my boilers pipes are crossed bonded but when looking further the earth wire is cut and doesnt go anywhere.there is a fused switch to the boiler and was wondering if it was ok to to wire it to the earth in there as i cant get it back to the consumer unit without ripping the house apart
Please confirm if the fuse board has rcd protection (ubits with a test switch) and what earth cables terminate at the MET (which is normally by the mains head / meter and is normally a shiny terminal block with green yellow cables on it).
As mentioned before, lets see if you need this before doing any work!
The pipes are bonded together, not to anything else.
Plumbers like doing this but it is not necessary (except in exceptional circumstances).
