I have around 1 bar pressure (tested this morning at the mains stopcock) and my main bathroom is upstairs which gets minimal shower flow, and the combi for the whole house is in the loft. The bath which is also upstairs also takes more than 20 minutes to fill to anything like a decent level.
So I'm trying to work out the most appropriate (and cost effective) boosting solution.
I've been looking at installing a Draper BP1 55l/min booster pump in my garage, and taking the inlet from a pair of 50gal tanks in my garage attic which is at ground floor ceiling level, with the output going to the domestic cold water, which in turn feeds the combi in the loft. I was also going to put mains water to the pump output with a pair of non-return valves (from pump and from mains) so the only direction of flow can be towards the domestic cold water and onwards to the combi. Obviously, normal operation would be cold water via the pump, but could still be direct from mains (with poorer pressure) in the event of loss of power to the pump.
Reason I'm putting it in the garage is because I read that noise may be an issue (pump spec says 85dbA) - and also that's the only place I have room for the tanks as I've just converted the loft to an office space. Lastly, there's already a feed direct from the incoming 28mm plastic pipe to a tap in the garage just in the right place.
Is it okay to feed a pumped supply to the combi? For that matter are the draper pumps designed with domestic supplies in mind? Anyone done anything like this before?
Should I be shooting for around 50l/min AT THE SHOWER? The pump manual (downloaded) says max 55l/min, but of course, that's assuming zero head.
