This would also give me much better flow for my garden, where the hosepipe presently gives out no more than a limp squirt!
So you have 1 bar static pressure and poor flow from the mains cold water. Assuming your mains pressure never rises much above 1 bar, I wouldn't recommend an accumulator in this instance.
The problem you have is as much to do with pipework sizing as pressure. Have you measured the flow rate at the outlet closest to the incoming mains, normally a garden tap or kitchen sink cold tap.?
To cut a long story short, you original idea of boosting the incoming mains is along the right lines . Why not consider a Grundfos Home Booster?:-
http://www.grundfos.co.uk/web/HOMEuk.NSF/MDR/DMAR-6RZKWV?OpenDocument
