Using this cheap imported tat as an example:
http://www.screwfix.com/p/15mm-isolating-valve-pack-of-2/65251
Cant find any bore dimensions any where, looking at the orifice it appears to be reduced to about 10mm in size, does that sound correct.
With reasonable water pressure that shouldn't restrict water too badly ?
Found this:
http://www.tlv.com/global/TI/calculator/water-flow-rate-through-orifice.html
Assume secondary pressure will be virtually same, this tells me a 10mm bore at 4 bar will fill a 100 litre tank in approx one minute - does that seem plausable, seems very fast ... or have I got this wrong ...
Found this:
