Bosch 1200 washing machine
25 Sep 2009
Cleveland
You seem to be a well informed bunch I hope you can solve my problem. My Bosch 1200 washing machine won't spin. It does everything else fine, fills, drains, tumbles - it just would do the spin cycle. I checked the hose and impeller and they are clear, the motor looked fine but I changed the brushes anyway - still no good. Any suggestions where I look next ?
One last question are these machines covered by a one or a two year warranty ?
Thanks - pp
will it drain on its own , ie drain only program
possibly pump jammed , undo the front panel filter cover at the bottom and see what is in there
How can it drain if the pump's jammed :?:
An easy thing to check: are all the wires OK on the multi-plug connector to the motor. It's prone to a lot of vibration.
well i ask the question can it drain
because if not the pump is possibly jammed
a bosch wont spin unless the wash water can drain away
seems pretty simple to understand :?:
and defo the 1st place to start on a bosch :!:
Cakeman - I don't want to get into one of those points scoring threads but I think the OP established that the pump is going in his first post
ie: "It does everything else fine, fills, drains, tumbles .."
Even though I disconnected the block connector to remove the motor a further ger-ger-giggling (Arkwright quote !!) seems to have done the trick. So all's well that spins well.
Thanks for the replies lads.
photopro
