Bosch 24 cd bf constant slight filling, yes as per the heading
Boiler has a constant dribble/trickle from outlet via the 'blow off valve' which is presumably because the inlet has a constant trickle/flow in, the white key is NOT in position and the blowoff valve was changed to remedy the fault and same keeps happening/continued, so as not to disturb the blow off valve i bled a radiator to release the pressure down to 1 bar, it takes approximately twenty minutes for the pressure to increase un aided and then continues to trickle/flow from blow off out let, any advice please thanks.
(boiler works well during this saga..hope this lot makes sense)
