Our Bosch Excell SGS45E62GB64 runs through the program fine and the dishes clean well. The problem is that over the past few months it has become more and more noisy. At first we put up with it but now it is literally causing headaches!
The noise, probably in the 5Khz range continues throughout the 120 minute cycle. It stops occasionally when I think I can hear a valve opening and water either being directed elsewhere inside the unit or exhausted through the waste. It only stops for a few seconds, the valve switches again and the noise comes back.
I haven't pulled it out and tried to diagnose what is happening. Listening, which is difficult given that the unit is placed between two base units, suggests that the source of the noise is on the right hand side in the base.
My feeling is that the motor is probably on the way out. If it is that, I don't know if there are any serviceable parts inside or if there is something else which is a likely cause.
If the motor is on the way out I'm questioning if it is worth repairing. I would contemplate fitting a new motor but I have read that they are hard to remove and can result in leaks afterwards. Plus, the cost of the motor and the time for me or to pay somebody makes me wonder if my money is better put toward a new machine.
I wonder if anybody has any thoughts as to what may be wrong and if it makes economic sense to repair it.
thanks
Ian
thanks
Ian
