Can anyone suggest anything please
SMS69LO2GB/02 model
6 weeks ago - E25 error - water at bottom at programme end - blocked water pump message
Cure was – replace heat exchanger – the whole left side panel. Then worked perfectly. Engineer also said pump was fine. Been careful not to put very dirty dishes in there, so no chance of anything blocking –and the filter is very clean.
6 weeks later problem came back. Nothing had been touched by us. Emptied sump found a loose 12mm long screw in the bottom! Removed screw, tried it again – still flooded.
Goodness knows where the screw has come from but it isn’t blocking the impellor. I am not going to undo the clip in the sump as it wasn’t put back properly by me last time and… that is how the engineer last left it properly fixed – guarantees and all that – until next time I can speak to him.
But if anyone has the slightest clue as to what the devil is going on I am all ears as the problem has returned and the side panel cured it last time – which apparently is one of the main faults on these machines
many thanks
SMS69LO2GB/02 model
many thanks
