Bosch Exxcel 1200 Express Washing Machine F18 Problem
Look inside the door for a label with the full model details & note the "E number". This is essential when ordering spare parts.
Thanks. I must admit I don't know what to do next. . :?
The worst kind of fault is an intermittent fault..... :x
The drain pump seems fine.
I think I might start with buying and installing a new pressostat and see if that inproves the situation.
As I mentioned earlier F18 is a pump timeout error. In my opinion it would most likely be caused by a restriction, a drain issue, or the pump is defective & needs replacing. Sometimes a pump can bench test ok but when it runs under load it can stick or even trip out via the internal klixon. I doubt if changing the pressostat would help you very much.
The problem WAS the drain pump assembly.
Replaced the drain pump and all is now well.
Thanks for the help. . 8)
What we found was that when we gave the waste pipe a good shake a 1 cent coin was lodged at the very end of the pipe creating its very own non return valve. A perfect fit in the end of the waste pipe.
