Bosch Exxcel keeps draining and will not restart
25 Feb 2011
Monmouthshire
Washer worked fine when I put it into store for 6 months. Take it out and use. Works fine. Next time I turn it on the pump runs and it will not restart. No water out of drain.
Tip machine out through drain on back. About 1 pint of water comes out. Clean all drains. Run washer again and it works fine. Next day it is back to continually pumping and will not start. Repeat tipping out and it works fine for a few days. Now back to not working and pump running.
Any ideas? Thanks. Regards Fixitduck
Where/how was it stored...it may have suffered frost damage & popped an inlet valve. Sounds like you have a leak that needs tracking down :(
You may be right. It was stored in a gararge and there was a hard winter...
Probably was frozen and probably leaking inside. Where do you start taking it apart. From beneath?
Thanks. Regards, Fixitduck
Inlet valve/valves under the lid. Lid off is a good start (pull the plug first). Post the model details & E-number if you need further info (on a sticker in the door opening).
