Bosch Exxcel SGS45E08GB
17 May 2011
Berkshire
Hello I have managed to get the connector and plumb it all in! Unfortunately when I switch it on it makes all the usual noises but the timer doesn't count down from 130mins and the dishes aren't gettng sprayed with water although the water is definitely coming into the dishwasher.
Can anyone help?
Thanks,
Allan
Have you done a reset to start with.
Does the drain pump operate for a short time on initial switch on
Drain pump goes off and it should fill for a short while (sometimes stops and starts as it gets to the right level).
Circulation pump should then operate.
Managed to find a manual and do the reset and now it seems to be working perfectly, thank you.
