Bosch greendtar cdi
21 Dec 2008
London
I have a bosch greenstar cdi boiler which is 2 years old.I keeop getting a "EA" fault symbol coming up.Bosch have replaced the circuit board twice and it has flashed back up after 48hours.Any ideas would be most welcome.
Bryan
First idea is to call worcester back.
EA is a "failed to ignite fault"
Its obviously not the pcb. :lol:
My first port of call is the condensate trap/pipework, if it is backing up you will get this fault.
Gas pressures need to be correct.
The negative pressure from the fan needs checking to see if the heat exchanger needs cleaning.
Could also be: Gas Valve, ignition electrodes, flue problem.
Have a look at the flue terminal, they have a habit of falling off and causing combustion problems.
Intermittant faults are a nightmare to sort i'm afraid.
Thanks for the quick reply,info very useful.Have got them coming round tomorrow.
Thanks again
Bryan
Had bosch come round this morning,read out the list of faults that Scatmanjohn had given to what could cause the problem,one being the water trap not getting rid of the water so it causes a build back,SURPRISE SURPRISE the engineer thought of that while driving to me!!!
He hadn't checked it last time.We moved the pipe so the water could run into the waste pipe easier.Hopefully this will cure it (fingers crossed!)Don't take offence,but I hope I don't have to post another message of help on here,but if I do I know where to come.Thanks for your expertise and knowledge.
Many thanks
Bryan
