Bosch not draining
21 Apr 2011
Hampshire
I have a Bosch WFL 2060 which I purchased recently and it hasn't been draining (since we got it). It completes the wash cycle, but then stops after attempting to drain for a little bit.
I have checked:
- drain pump works fine
- drain pipe is not blocked
- filter is not blocked
- sump joining the drum and pump is clear
See pitctures below.
Filter appears to be snapped
What the filter should look like
Could the pump not create the suction it needs because this piece is broken?
Thanks!
