pearce_jj said:
PTH: . I presume your drain exits from the top of the machine then?
they make m/c as economicly as possible so why run the waste pipe inside the m/c i bet it exists at the bottom (so less pipe used)
the things you have to consider with a w/d are:
the "extra bits" are secured to the main drum, in spin mode they are still there, which means they have to be able to withstand a lot of vibration (sometimes they didn't)
by design they do dry differently (no fresh air) so the clothes never come out as dry as they would in a t.dryer
a td sucks air in, heats it, blows across clothes and out via large hose
I did hear of one manufacturer (cant remember who) that changed all wd to wm because the dryer was so unrelaible.
I would not know about the 3 stats on a Bosch (only worked on HP)
as for a separate proper dehumidifier, it would cost too much
re: the routing of hoses i can not comment other than to say its a "design feature"
Its nice of you to say i am the expert on appliances, but i should point out, i was only a home laundry engineer, which meant i only worked on wm, wd, and td
I know a tiny bit about dishwashers
and even less about fridges
my d:w knowledge is this:
always mix cutlery as if two spoons or forks sit front to back water cant get in the gap
always clean things before you put them in dw (yes thats right rinse them under tap first, this is because a dw is NOT a waste disposal unit, it can not cope with the "bits" left on plates etc)
if you dont rinse things ketchup will turn all plastic in dw to pink
and egg will turn it yellow
they need a lot of salt
my only hope is no one gets a top loader problem, i hated them with a vengance
NOTE: if any one ever does get a tl it is normal for them to smell of burning on the first few times of use on the spin cycle ONLY, this is because it has a clutch and the clutch shoes are "bedding in"
