Bosch Washer
18 Feb 2006
Hi anyone out there tell me how to remove replace brushes on a Bosch Classixx 1000 WFL2062GB
Tilt and balance machine preceriously, position head under machine,using a flash light in one hand and a mirror in the other hand remove brushes from motor with your teeth :x
The brushes can be changed from the front. But if your not an engineer better off removing motor via 2 bolts at rear from the back or from underneath if your machine has no base.
