Hi hope someone can help...
The above boiler is not firing all the time here are the details
1. Periodically the boiler will not fire for both hot water or heating.
2. When timer is activated on the timer/control box I can hear the system click on and also hear a "tick tick" from the water pump/valves situated on the wall adjacent to the boiler connected to the pipe work that leads in to the house.
3. Red light on the boiler is lit and boiler not firing.
4. For the last couple of days I have had to remove the cover on the boiler press and hold the red button for a second or two then the fan starts and that boiler fires (after about 4 or 5 seconds).
One additional piece of information that may (or may not) be significant is that fact that the timer/control box (Honeywell) has some LCD digits that are missing or distorted. The boiler is regularly serviced and when fired produces plenty of hot water and heating.
Any Ideas?
Thanks in anticipation
Matt
Any Ideas?
Matt
