Hi
Sink is on an outside wall (well not literally). I have asked a plumber if a wall hung basin could be fitted in it's place. I have been told that I will lose some space as a false wall will have to be built to house the pipes. Even though the wall is an exterior wall (not a stud partition), is there still a wooden framework on the block work that the plasterboard is fixed onto? Can't the pipework go behind the current plasterboard, or do I defo need a false wall? Ensuite is not huge, so may have to change plans if a false wall is necessary.
