Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
In general, what I found is when I put my hand up against the wall in the extn, immediately above the skirting, the wall is colder than the wall higher above it. That is about a foot above the skirting is quite cold. In the old building this is not the case whereby there is no temperature difference on the wall itself.
thanks for your reply tony1851,
I couldn't really say whether it did or not (other than asking the builder). From your question, am I correct to assume this is Building Control requirement??
Also, I had a curtain fitter round yesterday who suggested maybe getting an "Energy Assessor"; do you think this might help at this stage or would they not be able to get a proper measure of "thermal efficiency" at this stage.
Cheers,
Jon.
If insulation has been missed off lower down, it's not a Building Control issue, rather than one of quality, which is the builder's responsibility; Building Control can't inspect every aspect of the work.
Don't bother with an energy assessor - not relevant.
I have now cranked up the thermostat in the hall by another 3 degrees and this brought the temperature up by 3 deg on day one (from 17 to 20 deg); however day 2 and it was only up by 2 deg. In the hallway and everywhere else the temp. rise remained constant. I gather from this, the extra heat in the hallway where the thermostat is located held heat nicely and therefore the boiler didn't fire up as much, this means the extn. isn't holding heat efficiently. All the rads in the old house are down to 2 or 3 on the TRV otherwise temp there goes to 25/26 deg!!
Cheers,
Jon.
