Why is that? Blockwork is porousBlockwork doesn't need protected, unlike a timber frame.
For water penetrationSo what? Blockwork doesn't need protected from moisture.
Even for timber frame the vapour barrier would be on the warm side (inside), not in the cavity.
Stop water penetration? I believe the foil facing insulation will do it that and drained cavityYou can add it if you want to.
What is you reasoning for wanting membrane? Membranes are normally used for the roof, where there is higher probability of water penetration. On a properly built house, when there is no unusual defect or leak, the chance of water penetrating the wall is low. Therefore membrane isn't used.
Wherever there is a clear cavity (ie in a traditional block + insulation + cavity + brick/block wall construction) you do not need a membrane because any rainwater getting through the outer skin will trickle down the inner face of the outer skin.You can add it if you want to.
