I want to run bricks on edge (side by side, not end to end) at ground level so I can gravel one side and put plants in the other side.
I've dug the trench (20 metres in length) and got rid of the dirt. I just need someone to lay the mortar footing and then lay the bricks, butted up against each other (no mortar bed between bricks).
I've been quoted £200 to lay the 20 metre run, that's with me digging the trench and supplying the bricks, sand and cement.
Is that a bit expensive for just the labour?
Many thanks.
Many thanks.
