Brick outbuilding within 1 meter of boundry 18sq
1 Aug 2004
Hi all,
I fancy the idea of removing my man shed and installing a bigger brick outbuilding local planning said all ok (They explaned the 50 percent rule and max 2.5 meters height so happy with that)
Iam confused about building regs for the within the 1 meter rule can i build it this close as long as its non combustable material slate roof and brick walls? the overal size is 18SQ meters.
Any help would be much appriciated ;)
9 Apr 2010
Hertfordshire
I built one in my old house but I made the walls out of timber and clad them, so I had to be 1m away from the fence on both sides and the rear. If doing them in brick/block then they can be right up to the fence.
Andy
1 Aug 2004
Thanks alot Andy,
Thought that was the case was slightly confused with there writing up on website ;)
