Brick pillar gate hinge brackets
  • Thread starter Thread starter RMS
  • Start date Start date
RMS
8 May 2006
Hi all
I am going to be having brick pillars built for wooden gates. Can anyone recommend the best brackets to use that sit within the brick work?
Your help is appreciated.....
You want a hook and band type arrangement with these build-in hooks....
However if the gate is particularly heavy, and there is little masonry to secure the top hook then you may need to involve a steel column concreted into the ground
