Bricking up old fire place
12 Sep 2020
I've just removed the wooden fire surround and hearth from a first floor fire place which we want to block off.
The next stage in the process would be to seal off the fire place before plastering. I presume that the best way to do this is to brick it up (using an air brick to keep some ventilation) but I just wanted to double-check whether anyone has ever taken a different approach to this?
Assuming that bricking up is the way to go, I gather from some other guides that it is advisable to use frame cramps. Does anyone have any views about how essential these are? The fireplace is fairly standard size - certainly not particularly large.
Many thanks in advance for any advice that anyone may have!
I've just blocked with blocks and cement then plastered. Always have a vent in front or side to keep air blowing through
