Bricks on top of wall at the side of the roof
28 Aug 2024
Picture to illustrate what I'm talking about:
There's a line of bricks on top of the wall just at the side of the roof. I had a couple of roofers in to inquire about ventilation (another thread/discussion - one said I don't need to, one said I need ridge vents AND tile vents), and while they were there asked them about those bricks.
They said the bricks were probably left behind by the roofers when the new roof was installed (we just moved in this year, roof was probably done about 5ish years ago by the previous previous owners, looks well done and in good condition, with proper membrane as can be seen in the pic). In some spots, again as can be seen in the picture, the bricks aren't there anymore.
I'm putting Kingspan insulation boards between the rafters now, and roofers advised to get rid of the bricks so that I can push the Kingspan down all the way to reach over the end wall. Which I did in some places. But in some spots, the bricks seem quite hard to remove - some mortar still left to keep them in place. They don't seem to hold anything, and in my mind just prevent potential ventilation coming up from the soffits, and if I don't push the insulation over the wall but "stop" before, IF there's any condensation in between roof/membrane and the Kingspan (I'm leaving a 50mm air gap) that condensations is dripping onto the ceiling boards.
Thoughts? Should I hit the bricks that are still in place with mortar to make sure I can get rid of all of them, or leave them as they are? Does anyone know if they were supposed to have a function, or just "leftovers" from old roof structure?
Because I want to put something (like PVC cladding or plasterboard or so, we're still shopping around) on the rafters to make the loft look a bit nicer (no, we're not doing a full-on loft extension to turn it into a living room). Anyways, the question was about the bricks and if I should/can remove them, as advised by roofers rather informally, to make sure the insulation goes over the wall. Which is also what I've seen in videos and online descriptions and everything else I've researched, but I thought I could get +1 opinion here.
No one? I circled what I'm talking about - I just want to know what those bricks are, why they are there, and if they're better to be removed (for more ventilation/airflow) or if they serve a purpose and should stay.
I can't see them serving any purpose.
They can be removed.
Thank you both! Gone they will be soon.
Why insulate if you want airflow - it's either a warm loft or a cold loft...
See #3, I just want to make it a bit "nicer", maybe turn it into a "hobby room" - not for regular use and as an official used space but for example sometimes when both me and the missus have calls one of us (i.e., I) can escape up there. Obviously not in super cold freezing winter, I don't want to turn it into a warm loft with heating. But just to have it a bit nicer, that's all. Some other houses in the street have done the same, we saw that when we viewed other houses around here, and it inspired us to do the same.
Anyways, case close, thanks all!
