Bristan 1901 shower dripping
29 Jan 2012
Dorset
Had a dripping Bristan 1901 shower mixer that stripped its threads on the on/off flow control, so bought a complete new valve. Fitted it but I'm getting a slow drip when off. Cranking more on the on/off flow control makes no difference.
Just for a test, I took out the thermostat module and spring. The on/off flow control works perfectly, no need to use any pressure on the handle. No drips.
Could the new valve be faulty?
Obviously the spring in the thermostat module is pushing against the whole valve unit, basically forcing it open. As you close the valve it has to compress that spring. Just wondering if the pring pressure is making the valve body go slightly out of square o the o-ring doesn't seal.
Any ideas?
