Broken Boiler. No Hot Water or Central Heating!
20 Nov 2005
Hi there,can anyone help me with what this problem might be?
I have a Glow worm Micron 30 ff and to start off with the problem was that the boiler turned on (meaning the pilot light was on and making a humming noise) but it didnt actually fire up to produce hot water or central heating. Now when the timer comes on nothing happens, no pilot light, no noise,no nothing!!! :confused: :confused: Help me i'm cold! :( :( :(
Your help is much appreciated!
Amy
Unfortunately it could be many things.
Humming could be fan seized or gas valve solenoid, or even a dry joint on the pcb. The change to no noises could be the fuse has blown, either 3A in the main supply or a fuse on the pcb itself.
Once power supply has been restored can you hear the fan running (hum) and feel air moving at the flue exit?
