broken manhole cover
14 Sep 2009
Hi all,
I have an old manhole cover with a broken frame (3 of the four corners are broken). Over the last 80 years most of the mortar has worn away so that the cover and frame are loose and can be lifted clean off. Now that I have moved things around in the garden, from time to time people walk on the manhole cover so I am keen to get this fixed ASAP. A replacement cover+frame isn't really an option due to cost and size (approx 700mmx600mm, so not standard). So I am wondering whether in principle it would be secure enough to knock off the old mortar and lay the albeit broken frame onto new mortar (trying to get it square.....) and replacing the cover. Or is there maybe some way I can fix the frame back together?
Any thoughts/suggestions?
TIA
wrathkeg
If the frame is complete, its straightforward enough for the frame to be bronze welded back together - a blacksmith's job I guess.
When laying the frame back down onto mortar, take care to see that it is completely level or the lid will rock big time.
John :)
yes, the frame is complete so welding would be an option. does anyone have any thoughts as to whether something like this 'chemical metal' would work too, fixing the frame together until set into the mortar (which should make it easier to get level....assuming it got stuck together square)?[/url]
Epoxy putty is in fact an excellent product, and I've used it to fill a frost crack in an engine block for example. It could well work in your case if applied to the outside but get rid of the rust first!
No blacksmiths near you, presumably? Its a dead easy welding job.
John :)
Under a spreading chestnut tree the village smithy stands - And while the smith is gone away the village idiot ****es on his forge :shock:
