- Joined
- 22 Aug 2006
- Messages
- 8,012
- Reaction score
- 1,571
- Country
I've fitted two Sidewinders myself, but not for this purpose. And not for a few decades.Well, I've fitted several heating coils into HW cylinders this way so I'm certainly not wrong. I don't intend to reply to any more of your rather rude comments.
Look at the cost now - it is almost never worth it even for a special case
It is correct that it is not normal to do this when a coil is leaking. If the coil is corroding, what's the rest of the cylinder like?
Nobody has a clue so it would be stupid to use it more.
You are wrong. If you take correction as rude, then get things right, simples.
Let's see how many plumbers chime it to say they routinely fit a (rather expensive) Sidewinder into an old leaking cylinder.
Persistently writing things which are not true, means it would be better to stop completely.
Some forum "contributors" have a need to write something, regardless of whether it's irrelevant, misleading and/or guessing, outside their knowledge. They are a nuisance.
I suggest you stick to your experiences.
