Brush on silicone remover
17 Apr 2007
I'm attempting to remove the frame to brick sealant around a door frame. It had split away from the frame but still stuck to the bricks.
Thus far, have tried Zep solution from TS but it didn't have a noticeable effect on softening/ dissolving the sealant.
I presume the sealing is original and its a 2003/04 house build although no idea what the sealing type is.
Anyone know of a good product?
You need to remove what you can first by carefully cutting away then use the solution on the remaining silicone
