BT external bell (probably 80db)
21 Apr 2014
Gloucestershire
Hi
Strange request, I have an external bell that I want to wire up so that it will ring on a button.
I've seen posts on other sites that say its 12v, so will it work if it's wired to a 12v battery via a door bell switch?
Thanks. Steve
If it is a modern electronic one it might but the old 'mechanical' ones use A/C to power them, and no they cannot be supplied via a step down transformer because the ring frequency is not the same as the standard mains frequency.
It might be possible to adjust them but not a definite yes you can.
Step down transformer > Rectifier > Inverter > bell?
Talk about using a sledge-hammer to crack a nut!! Cheaper to buy a loud standard bell.
Funny you should say that, I have actually used a sledge hammer to crack a nut and I must say it's a very effective approach. The best method I found was to stand the nut on an anvil and light tap it with the sledge.
50 Hz might work but won't give a good ring.
You really need a Converter Ringing which will give you a 17-25 Hz output
http://www.britishtelephones.com/menuconr.htm
You'd probably be better to use a Masterbell which you can run off an ordinary bell transformer (or if the press switch and wiring is suitable, a mains powered version)
http://www.discount-electrical.co.u...2-masterbell-grey-6-inch-security-bell-12v-ac
DC versions are available
http://www.discount-electrical.co.uk/PDFs/Friedland/Friedland_Masterbell.pdf
