Hi there,
I have recently been having an issue with the actuator on my boiler, still havent got around to replacing it as yet so manually turned the valve on HEATING as a temporary measure.
http://www.diynot.com/forums/plumbi...itching-manually-setting-help.345072/#2581390
I know have a new issue, when the boiler kicks in the pipes start clanging and i get too scared to ride it out and turn it off!
If i then bleed the nipple valve in my airing cupboard lots of air comes out then finally water. I can then restart the boiler and after a bit of groaning it will come on.
My problem is that its getting worse, I now need to repeat this process about 6 times before the boiler will come on and it seems my downstairs rads arent very hot anymore.
I also hear bubbling noises when the boiler kicks in as if the pipes are full of air. I cant work out though how this air is getting into my system?
I can bleed the rads and a little air comes out before water, like i say the nipple near the pump in the airing cupboard is constantly filling with air.
I have checked the feeder tank in the attic and it is full, could it be blocked somehow?
Thanks,
Roverblue
Thanks,
Roverblue
