Buderus boiler/Hive connection
1 Dec 2023
I’m trying to connect a hive single channel wireless thermostat. I’m having a few issues on trying to get it to work with my boiler and how to wire it etc. any help would be great.
The white and brown is the current 24v thermostat, are you saying when I connect the hive it needs to be in 1 and 3 on the boiler or 1 and 3 in the hive receiver
The existing stat was working fine before hand, I have however reconnected it since and it no longer works. I’m thinking it could be the main control PCB that would need replacing? I’m 100% sure I’ve connected it correctly, I’ve also changed polarity of the connections to double check
I'm afraid, if it worked before, and now doesn't, it very much suggests that something hasn't been connected correctly.
And what model was your existing stat?
Can you post a picture of how you have reconnected your old stat?
